Cardboardcat15 Posted June 24, 2015 Report Posted June 24, 2015 if you just want loud, sell those 3 pairs and get two pair of PA 6.5s and some super tweets. It'll sound like ass but it'll be louder than 3 pairs of those 6.5s. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
757lmj Posted June 24, 2015 Author Report Posted June 24, 2015 K obviously I don't want it to sound like ass. Midbass. yes tweeter in the middle of them. I have these already that's why I'm trying to make them work. I'm not familiar with mids and highs really
reedal Posted June 24, 2015 Report Posted June 24, 2015 I personally would not want a box for 6 coaxials. If you're set on using them, then one in each door (if you have a four door and want a rear stage for passengers) and keep the third set as a backup or fiberglass/buy a kick panel to put them in. They're good for ease of install, but if you're looking for a sound quality setup, they're not for you due to lack of staging and EQ-ing. What are your goals for your system? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
aculous Posted June 24, 2015 Report Posted June 24, 2015 More drivers is not your answer for a clean setup. Ditch the behind you idea....its not a good one. A loud clean setup can be achieved with a good quality component set (probably not infinity, personal opinion) and a good quality amplifier that does more then the rated power of the speakers. With a amp that can overpower the component set you can turn down the gain and play them louder and cleaner with less distortion.
757lmj Posted June 24, 2015 Author Report Posted June 24, 2015 My goals are to hear all of my music not just the bass. I have no treble at all compared to my bass when turned up
757lmj Posted June 24, 2015 Author Report Posted June 24, 2015 I want the rest of my music on the level my bass is basically
aculous Posted June 24, 2015 Report Posted June 24, 2015 buy two of these. http://www.usspeaker.com/ciare%20ndcx8-1.4-1.htm All you'll need is 225 watts into 4 ohms RMS. (wire both drivers in series) you'll need a electronic crossover as well. Or just use your amp. http://www.woofersetc.com/c-3-amplifiers/c-28-two-channel/p-11344-p1000x2-rockford-fosgate-1000w-2-channel-punch-series-amplifier.html or http://www.woofersetc.com/c-172-speakers/c-10-compon-speakers/c-40-65/p-11745-11km65002-kicker-65-200w-rms-hlcd-tower-km-series-tower-component-speakers-system.html ^^these are not serious examples^^ I would upgrade the amp if you want more power and the components. Realistically 1 set of components should be fine for you. I would run the components at 4 ohms but thats my opinion and run a amp that does well over RMS power for the components. I usually double it...which is overkill but whatever.
757lmj Posted June 24, 2015 Author Report Posted June 24, 2015 The amp was free that's why I was planning on using it. ok thanks for the help
