Will I rub with 33's and a leveling kit?
I have 33" on my truck right now, the tires only hit the fender when doing a hard turn either way & on an uneven surface. Usually coming out of my drive way. So i would say no, if you lift 3" it definetely should not. Also dont just crank your torsion bars you will hate it. I'm 2wd though so it could be different. I feel like my springs sag a bit aswell.
33s aren't the problem, the wheel width/offset is the problem. There's a guy on the duramax forums with a NNBS on 37s with factory suspension...
I rubbed with 33s with my life set at 4 inches. On 10.5 -24 offset. Cranked it up. Seems good now.
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
  • 5 months later...
2012s with -44mm offset might rub slightly but some trimming and u will be fine in the front
2007 chevy avalanche
triple singer 350s, pioneer avhx4800bs, 14 krome ka8s 4 st50 4 st30 tweeters, pro ad4000.1 crescendo 800.4
crossfire xs8k 3 15s tbd blow through ported
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
