Mechman Alternators
only getting a 14.0 volt charge with new alt..
batts sit at 12.6
sure i'm over thinking this, but 400plus dollars..just want to know why my mechman is best at idle (14volts) and goes to (13.7) when driving or revs.
sorry if i'm repeating myself..i'm sure i am..
i'm going to get a new pulley from them and see if thats the problem,(mine came with a stock pulley 2.25").the site says it comes with a smaller pulley(1.75) and i will need a new belt..the instructions also say that.
and there is a picture of my alt with a smaller pulley on it on the site and every youtube vid i watch with my alt..Sooo..in a few days or week or so..i will check back in with results..
thx u everyone!!!!
2004 F-150 Lariat
2 PGold 800 rms amps to subs
1 Hifonics 640.4 brutus to m/h
4 a2-65 6" percisionpower-mids
4 PT.2 tweets percisionpower-hi's
2 12" PA mofo's/box by "dave the box guy"
big 4 0/1 g front to back / 2 optima yellow tops
nutin special....
Because your batteries float should be 12.8 to 12.9 or so. Your resting voltage should be handled.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
both batts are newer..how do u handle the resting voltage?..charger got them up to 13 befor it turned off..then after a bit they go back down to 12.6 or so
2004 F-150 Lariat
nutin special....
same batts that were on the stock last week at 14.5 ..so i duno
2004 F-150 Lariat
nutin special....
guys at oreillys let me exchange both batts...new ones had shelf charge of 12.55..took home charged up..came to rest at 12.8...mechman still at 14..falls after warm up..hit some heavy bass,got the back battery to drop to 11.2 volts(but did bounced rite back to 14)..put stock back in..14.5 all day even after warm up..was told buy seller that my pcm wont let alt charge to hi..but stock and other after market do...sending it back..end of story..
2004 F-150 Lariat
nutin special....
what kinda wire are ya running? and terminals... as stuff heats up it creates resistance in the wires ect. make sure using ofc copper all over
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
end of story
did u specify on ur quote request what voltage u wanted it to charge at? i have had a few cars that only charged at around 13.8,i had bad connection on my mechman so after fixin that it went from 14 tops to bout 15.2 tops
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
well...now thats my fault..i did fill out a quote..waited 4 days..then just got the only one that the site showed they made for a f150.. quote came back right after i bought.they told me that it was the best one for me,if i got the one with the controller ,i was more than likey guna have problems with PCM and dash lites
.befor i send it back , im goin through everything hoping somthing is wrong,but dont think there is..stock runs just fine with everything the way it is..i have my meters on front battery and back amp furthest away from back battery..moved front to the alt and got 14.2 at start up/idle(cold or warm)..drops to 13.7 when over 1200 or so rpms(back meter is same a front meter with 17 feet of wire between..id say the wire is good-0/1 g CCA)..im fine with 14.2 at start up.but cant figure out the drop when driving..i still get hella lite dims.also just noticed some pulsing in the lites alswell..didnt notice befor..i have no idea what that could be..didnt have with other alts..
only reason im going to send back is cause i think mine should have a smaller pulley on it,and i dont wana void any warranties changing it myself .
2004 F-150 Lariat
nutin special....
  • Who's Online   0 Members, 0 Anonymous, 1461 Guests (See full list)
