Sky High Car Audio
Whether it's the lug on plastic or a washer or nut, there's still going to be a metal connection with voltage and possible resistance touching plastic. The order in which you connect them won't matter in that aspect if you're trying to avoid voltage on plastic...
I don't see how people say the set screw is less connection than a lug and bolt/nut
Edit; not in this thread, but in past threads
Edited by reedal
i just want metal on both sides of the lug. So, leaving the washer on the bottom should do that. I may add a larger one if i still have clearence issues. just for more surface area.
Got it. Understandable
The set screw ones like i got I dont care for but I get them because I dont want to solder a million lugs, in my case I got 18runs, 18 fuse holder, and would of been 36 lugs to solder. I really need to buy a crimpers badly though. LOL
Why I dont like the setscrew type is because I crank my setscrews so damn tight that the tiny screw that holds the adapter to the plastic snapped. But thats not the products fault though since i like things super tight.
ive broken 6 blocks off just snugging the ss type up.... I dont really care for the FB's to be honest........
Ive done my own work to mine (adding a washer to the bottom fastener of the block, to not snap the plastic, used a mill to camfer the incoming of the block, used a larger gauge washer on the fuse fastener so it tightens better when the wire is shoved in, among other things) and ive still seen charcoaled fuses.
I like the higher priced ones, but, these,.. i just dont know.... ive fought em for 2 years. Ive only ran the SS type
  • Who's Online   0 Members, 0 Anonymous, 4697 Guests (See full list)
