26 rim/tire mileage to rotate
How often would you guys recommend rotating my 26s?
05 escalade ext awd
Current Setup:
Mechman 370a Alt 4 pin
DC Triple Alt Bracket
XS3400 Battery
4 Ampere 6.5 components 4 tweets
Ampere 150.4 way
Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms
DG Roll Pan
LED License Plate Lights
I did mine every oil change so around 3-5k miles. I do this on my current truck as well with 22s on 33 toyo M/T. Pretty much every vehicle I've owned I've done that method that had rims upgraded.
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Ok that sounds good, im assuming the fronts will wear out much quicker due to those being the steering tires.
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
thats what i do every oil change, mine wear alittle on the inner edge but dont do is as much when i rotate them often
