LoweredA34 Posted July 26, 2015 Report Posted July 26, 2015 2 CT Sound Strato 10's on a Crescendo 1.5k @ 1 ohm. I listen to mostly hip hop and r&b. Max Dimensions: 35w, 15h, 36d Wants: Ported @ 34 hz Directly from http://ct-sounds.com/ T/S Parameters Dual 4 Ohm Fs 39.499 Hz Qts 0.476 Qes 0.53 Qms 4.684 Vas 14.909 SPL 84.3 dB Box Specs Sealed 0.5 ft^3 Ported 0.8-1.0 ft^3 Dimensions Overall Diameter 10.6″ Cutout Diameter 9.3″ Mounting Depth 5.7″ Displacement 0.10 ft^3 L
Ninja_v1.0 Posted July 27, 2015 Report Posted July 27, 2015 Just what vehicle is this going to? yea we need some type of information here When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
alex912005 Posted July 27, 2015 Report Posted July 27, 2015 Here you go. This is a normal slot port box. The one on the right is the same design only the re audio calculator shows a 3d model of the box, and doesn't take into account subwoofer displacement, so that's why it shows a different tuning frequency. But it does show you the cut sheet. For this to work you have to use the same wood thickness. Just go to re audio box calculator and input everything like in the picture, and then you can zoom in on the 3d model to see how everything goes. My Build Log
LoweredA34 Posted July 27, 2015 Author Report Posted July 27, 2015 Just what vehicle is this going to? 06 Nissan Maxima.
Joe X Posted July 27, 2015 Report Posted July 27, 2015 So here is a suggestion, power: to subs rated, amp subsonic filter to 30Hz, minimum port clearance 3", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside
