amp gains set to zero and still have distortion....
SJonus
heres what iv done and what i have....i have a factory ford head unit with a schosche slc-4(havent had problems that i know of in the years iv used it).thats running two set of rca's to the back..i adjusted the volts on the loc to have 2.5 volts(its max was 5+)..
i have a 4 channel amp and 2 mono amps daisy chained off of the 4 channel..the 2 mono amps are rated at 600 rms..so i needed to set gains on them to around 34 volts..
Well, when i turn my volume up and have my multimeter ready the reading is at 45 volts with bass knob up..13 volts when off..and the amp gains are at zero...question is..should i not touch the gains and leave a zero and just use the bass knob to turn it up?..or do i have somthing screwy goin on?
thx 4 any help
2004 F-150 Lariat
2 PGold 800 rms amps to subs
1 Hifonics 640.4 brutus to m/h
4 a2-65 6" percisionpower-mids
4 PT.2 tweets percisionpower-hi's
2 12" PA mofo's/box by "dave the box guy"
big 4 0/1 g front to back / 2 optima yellow tops
nutin special....
What are you using as a bass knob?
the bass knob came off of another amp..not sure what brand..when i move the knob the volts go from 13 to 45 half way up..mayb knob??...ya and the schosche..can u recommend a LOC thats good .sorta cheap?
2004 F-150 Lariat
nutin special....
Well if your bass knob came off another amp then that can be part of your problem also.. Get a pac lc-1. And cheap and good don't really go together but the audiocontrol is a good one, I have the audiocontrol lc6-i
So there knob is most likely a bass boost control then.
Ditch it and get a pac-lc1.
what about the LOC's that have a bass knob..are they worth a crap?..or should i find my original knob and use the amps gain?
2004 F-150 Lariat
nutin special....
2004 F-150 Lariat
nutin special....
  • Who's Online   0 Members, 0 Anonymous, 741 Guests (See full list)
