ajsmoke Posted August 8, 2015 Report Posted August 8, 2015 title says it all Stock front battery - One deep cycle battery in the trunk + 240ALT what r the pros and cons of this setup someone told me i need to get an isolator the car will always be runing when playing so i dont see why i need an isolator does the isolator keep my main battery separate from the rear battery even if the car is runing? let me know
islandpride684 Posted August 8, 2015 Report Posted August 8, 2015 If they are 2 types of diff batteries then run a isolator, if not no need for one....the isolator just prevents one battery from draining the other, but since the car will be running then no need for an isolator....just don't play with the car off if you wanna read up on isolators http://all-about-lead-acid-batteries.capnfatz.com/all-about-lead-acid-batteries/lead-acid-battery-management/how-battery-isolators-work/ Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
jcarter1885 Posted August 8, 2015 Report Posted August 8, 2015 Isolator not needed really, why not just switch the front battery as well? Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Carbon Posted August 8, 2015 Report Posted August 8, 2015 Unless your planing on playing your system with your vehicle off until the battery dies, you shouldn't need an isolator.I would only use one for a marine application, Sucks to be dead in the water.
MrSkippyJ Posted August 9, 2015 Report Posted August 9, 2015 No need for an isolator F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ajsmoke Posted August 9, 2015 Author Report Posted August 9, 2015 If they are 2 types of diff batteries then run a isolator, if not no need for one....the isolator just prevents one battery from draining the other, but since the car will be running then no need for an isolator....just don't play with the car off if you wanna read up on isolators http://all-about-lead-acid-batteries.capnfatz.com/all-about-lead-acid-batteries/lead-acid-battery-management/how-battery-isolators-work/ so what my setup is fine ? normal battery up front deep cycle in the rear no issue ? Isolator not needed really, why not just switch the front battery as well? why ? its brand new Unless your planing on playing your system with your vehicle off until the battery dies, you shouldn't need an isolator. I would only use one for a marine application, Sucks to be dead in the water. no i wouldnt play with the car off but i'd like to know if this is a bad setup or its alright ? ha No need for an isolator thanks so thats fine stock front and deep cycle rear ?
reedal Posted August 9, 2015 Report Posted August 9, 2015 Yes. It's fine. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
ajsmoke Posted August 10, 2015 Author Report Posted August 10, 2015 Yes. It's fine. thanks a ton bro cause on another forum i been told to change my front to AGM cause the battery will have different discharge time / rate thats why i was curious
reedal Posted August 10, 2015 Report Posted August 10, 2015 Yes, it will. Will the better battery have a diminished life over time? Yes. But as a daily driver, it really won't matter. You'll be fine. It'll still have a few good years, and you can have the battery load tested as often as you want to keep track of its ability to perform. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
ajsmoke Posted August 17, 2015 Author Report Posted August 17, 2015 Bought the xs power d3400 off ebay shipping was overkill ( i had no option ) cant wait to get my singer alt
