arcaudioman Posted August 19, 2015 Author Report Posted August 19, 2015 Return? And by voltage are you talking DC voltage? If so then yeah I've always been on the low side, but it's never got to the point of shutting down from power or thermal.
420c Posted August 19, 2015 Report Posted August 19, 2015 You could start by checking your voltage from your alt to your batt to your amp if you havent done so to see if there are any abnormalities. Then you can use a multi meter for refrence to see what kind of numbers your getting out of yhe amp ( http://www.stevemeadedesigns.com/board/topic/163181-set-gain-with-multimeter/ ) unless you know how to clamp your amp to see what its doing. But it sounds like the amp took a hit somewhere so you probably could hit up dc audio direct to get a real idea and if you like that amp theres repair guys around you just have to hunt them down.
Dan2427 Posted August 19, 2015 Report Posted August 19, 2015 Alpine head units need to be set with sub out at +15 to get full RCA voltage. Unless something has changed. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
magillaru Posted August 19, 2015 Report Posted August 19, 2015 Alpine head units need to be set with sub out at +15 to get full RCA voltage. Unless something has changed. This. Set sub level at +15. Singer Alternators Team Asshole #anothershittysingerbuild
arcaudioman Posted August 19, 2015 Author Report Posted August 19, 2015 Ok I'll check that out, thanks
arcaudioman Posted August 19, 2015 Author Report Posted August 19, 2015 I have the stinger volt meter in the dash hooked at the amp and the power seems to be consistent with alt and batteries. I do need a bigger alt though, I drop to 11 volts at the deep bass lines. This is my daily driver I commute 2 hrs each way to work daily and this keeps me awake. Hopefully my amp is ok, it still plays fine I'm just concerned with the sudden need to increase gain, it's been constant for 2 years
