LoudPackRacing Posted August 12, 2015 Report Posted August 12, 2015 What are some loud components that will keep up with a 3,000 watt sub stage in a 2000 trans am? My budget is about $250 per set.
firebirdude Posted August 12, 2015 Report Posted August 12, 2015 Just want loud huh. Then there's no replacement for displacement. Cone area and power. How many sets can you fit up front?
gckless Posted August 12, 2015 Report Posted August 12, 2015 What exactly is the substage. 3kW doesn't tell everything. 3kW to a single 10"? 3kW to a pair of 15's? Do you want active or passive? Are you willing to treat the doors? Willing to glass or want stock locations? What do you normally listen to? Where do you want to cross? Need some more info here. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
jcarter1885 Posted August 12, 2015 Report Posted August 12, 2015 Have you went to you local shops to audition some to see what you like, all components don't sound the same. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
LoudPackRacing Posted August 12, 2015 Author Report Posted August 12, 2015 I plan on fiberglassing the door panels and running 2 sets per door I will keep then passive for now but I do plan on running them active and buying a 3 sixty 3 .. .I have 2 12" fi bls running 3000 watts together..I will buy some deadener from second skin to cover the doors and interior.I only listen to rap music.
LoudPackRacing Posted August 12, 2015 Author Report Posted August 12, 2015 Have you went to you local shops to audition some to see what you like, all components don't sound the same. No because the shops around here don't really carry quality speakers
White Lightning Posted August 12, 2015 Report Posted August 12, 2015 2000 Trans Am huh ... If I remember correctly, you might can fit an 8" driver in those stock door locations. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
jcarter1885 Posted August 12, 2015 Report Posted August 12, 2015 Have you went to you local shops to audition some to see what you like, all components don't sound the same. No because the shops around here don't really carry quality speakers Dont carry quality speakers or just brands you dont care for. Still it would help to know what type of tweeters you are looking for, prefer midbass over midrange etc. Its gonna be hard to get quality components for $250 but our definitions of quality may differ though. Have you shopped around to see what you like and what fights your budget? Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
LoudPackRacing Posted August 12, 2015 Author Report Posted August 12, 2015 What exactly is the substage. 3kW doesn't tell everything. 3kW to a single 10"? 3kW to a pair of 15's? What about hertz esk l65.5? Do you want active or passive? Are you willing to treat the doors? Willing to glass or want stock locations? What do you normally listen to? Where do you want to cross? Need some more info here.
