timc31610 Posted August 18, 2015 Report Share Posted August 18, 2015 Hey guys, I just picked up a 2003 PT Cruiser (I know not the best rep for a car but you work with the funds you have). I have 38"W x 18"D, 20"H to work with and was wondering if 2 15's would be out of the question. I currently have 2 blown Soundqubed HDS312 that are about to be sent bak to be repaired and I can go up to 15's while they have them for very little extra cost. According to my calcs with the above dimensions I can pull off about 7.9 cubic foot gross. Can someone suggest port area size? Or am I just hoping for too much? Should I stick with 12's? I will be powering them off of a Sundown SAZ-3000 at 1ohm with factory alt and two D3100's. Thanks in advance guys! My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
Joe X Posted August 19, 2015 Report Share Posted August 19, 2015 You would need to get 15s that work in tighter space or do 3 12s. Link to comment Share on other sites More sharing options...
timc31610 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Thanks for the response Joe. I may just have to stick to the 2 12's sadly. I can't afford 2 high powered 15's that would work in a smaller space. And 3 12's would be a tight fit. What would you recommend as far as a box for the two hds312's that I have Joe? Should I do subs up port back around 4.8 net? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
Polar Posted August 19, 2015 Report Share Posted August 19, 2015 4.8 is a sweet size for those subs 2000 Ford Ranger Sport Ext Digital Designs DD915J 4.91 net birch box, inch port @ 33hz FSD FZ2600 FSD FZ100.4 Pioneer DEH80PRS PRV Audio 6MB200-4 6-1/2" Midbass Woofers Tymphany BC25SC08-04 1" Silk Dome Neodymium Tweeters with Waveguide Link to comment Share on other sites More sharing options...
timc31610 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Maybe something like this? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
timc31610 Posted August 20, 2015 Author Report Share Posted August 20, 2015 NM that won't work, after re-measuring I only have 17" of depth at 20" of height. I have been playing with Torres too much and can't get it right...lol. I know I wnt at least 4.5 cubic foot net just not sure about port size and area. Any help would be appreciated! My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
timc31610 Posted September 4, 2015 Author Report Share Posted September 4, 2015 Ok, SQ has my subs and I am downsizing to 10's for space reasons. Im going for 2.5 cubes with around 40 square inches of port, subs up port back. This will give me enough room for my 2 D3100's in the back along with the sub amp and my 2 channel. Anyone have any suggestions? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
