Voltage drop with H.O Alt
Hello
I just installed a 300A Alternator on my 96 tahoe but the voltage drops real low to 11 and my radio shuts off...around 40% volume
I have a 2500w Bass amp and a 1200w 4ch amp
I ran a 0 gauge wire from Alt to battery
and a 0 gauge from battery to the chassis
and I have a duralast gold battery(autozone)
Do I have to get another an additional battery ? or just upgrade the Duralast battery?
thanks..
what brand of alternator did you get? did you crimp solder your lugs? did your connections have oxidation and corrosion? did you sand the pain in your grounds to bare metal? how tight is each and every made? and how do you know your droping to 11 volts? i would go and re check everything i sad and report back.
looks like a small block chevy.. from late 80's to early 90's is it a truck or suv.. looks like the engine was worked on
not that it has anything to do with the issue.. just something i noticed
the brand is Quality Power
I just crimped my connections I didnt solder im using knuconcepts 0 gauge ofc wire (there new)
I did sand all the grounds
Im using the stinger volt meter and a multi meter (measuring from the Alt)
its a 96 tahoe with the original 350 Vortec engine
  • Who's Online   0 Members, 1 Anonymous, 1822 Guests (See full list)
