feathered1iron Posted August 24, 2015 Report Posted August 24, 2015 What battery would you guys recommend to replace stock starting battery under the hood? 05 Escalade EXT 6.0 Also, do I need to replace anything else (wiring, alt ect.) when upgrading to a high performance battery? Thanks newb here Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
ToNasty Posted August 24, 2015 Report Posted August 24, 2015 (edited) Xs d3400 and a set of xs 551 side post adapters Doing the big 3 on that vehicle is a bit fucky but can be done Edited August 24, 2015 by ToNasty Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
bassman619 Posted August 25, 2015 Report Posted August 25, 2015 Xs 3400 Quote You need trunk space to get groceries and shit...bitches love groceries
chris@xspower Posted August 25, 2015 Report Posted August 25, 2015 Hi if you are just replacing the factory battery with no upgrade to sound system then yes the D3400 with side post adapters is what you would need! thanks! Quote
feathered1iron Posted August 25, 2015 Author Report Posted August 25, 2015 Chris, I just recently had 2 t1412 RF's put in a ported midgate box along with a t1500bd amp, everything else is stock. If I replace my stock battery with an XS3400 do I need to upgrade the wiring to the battery as I have not done the big 3 upgrade yet? Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
feathered1iron Posted August 25, 2015 Author Report Posted August 25, 2015 Thanks for all the replies so far guys. Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
ToNasty Posted August 25, 2015 Report Posted August 25, 2015 The big 3 in your vehicle is a little differant. You have to put your ground through thr battery current sensor Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
feathered1iron Posted August 25, 2015 Author Report Posted August 25, 2015 Thanks ToNasty, Until I do the Big 3 can I still install the XS battery without any modification? Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
ToNasty Posted August 25, 2015 Report Posted August 25, 2015 Just a 551 side post adapter Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
feathered1iron Posted August 26, 2015 Author Report Posted August 26, 2015 Thanks Tonasty, Also, which alternator would you recommend for my vehicle since its a bit different in that regard? Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
