Would this be considered as a good ground ?
Would this be considered as a good ground ? the red wire is that of my battery negative and the black one is from my amps, i sanded it down to the bare metal, no star washer, that metal part runs across the car at the bottom behind the rear seats, and the wire is 1/0 max length 1.5'
Hard to see in this photo, is the paint scraped down bare? Did you use a star washer, what does that metal connect to? How long are those runs? What awg is that wire?
I'll have to go with probably :)
Do you have a dmm? Can you load the system and measure the voltage drop across the terminal connector at the bottom of your picture (ground distro block?) and the battery connection at the battery post? even without loading you could gather some data on the connection with resistance measurements and voltage across the leads
What he said. It's a bad ground
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Use a dmm and measure the resistance between that point and the front battery.
My guess is it's high which is no good.
If however the resistance is real low you are fine.
  • Who's Online   0 Members, 0 Anonymous, 831 Guests (See full list)
