Broke_Audio_Addict Posted August 31, 2015 Report Posted August 31, 2015 They know their music and turn the volume down. It's pretty much unavoidable the days, the art of a quality recording has gone down the toilet. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Lakeshow94 Posted August 31, 2015 Author Report Posted August 31, 2015 They know their music and turn the volume down. It's pretty much unavoidable the days, the art of a quality recording has gone down the toilet. So would you suggest just resetting my gains at a lower test tone? like a -10 or -15 db tone? Especially since most of my music is clipped anyways 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Kyblack76 Posted August 31, 2015 Report Posted August 31, 2015 They know their music and turn the volume down. It's pretty much unavoidable the days, the art of a quality recording has gone down the toilet. So would you suggest just resetting my gains at a lower test tone? like a -10 or -15 db tone? Especially since most of my music is clipped anyways your thinking is wrong...... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Lakeshow94 Posted August 31, 2015 Author Report Posted August 31, 2015 They know their music and turn the volume down. It's pretty much unavoidable the days, the art of a quality recording has gone down the toilet. So would you suggest just resetting my gains at a lower test tone? like a -10 or -15 db tone? Especially since most of my music is clipped anyways your thinking is wrong...... what would you suggest? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Broke_Audio_Addict Posted August 31, 2015 Report Posted August 31, 2015 If you set at -15 you're liable to blow your speakers. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Broke_Audio_Addict Posted August 31, 2015 Report Posted August 31, 2015 I would suggest turning the volume knob back to the left. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Lakeshow94 Posted August 31, 2015 Author Report Posted August 31, 2015 If you set at -15 you're liable to blow your speakers. It's a slow sunday for me................ i went backwards. meant 0 odb 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Kyblack76 Posted August 31, 2015 Report Posted August 31, 2015 If you set at -15 you're liable to blow your speakers. It's a slow sunday for me................ i went backwards. meant 0 odb You should be using the -5 tone id expect. Are you sure you know where your DECK distorts at? Or did you set going through the amp? (bet i know the answer there) That said, if your playing over or under tune, you can build heat,.. some songs vs others can do it, rolling a window down or up can do wierd shit, maybe that coil in that driver is a turd.... i dont know. But there is a LOT going on. Fact is, you need to know your gear/build. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Lakeshow94 Posted August 31, 2015 Author Report Posted August 31, 2015 If you set at -15 you're liable to blow your speakers. It's a slow sunday for me................ i went backwards. meant 0 odb You should be using the -5 tone id expect. Are you sure you know where your DECK distorts at? Or did you set going through the amp? (bet i know the answer there) That said, if your playing over or under tune, you can build heat,.. some songs vs others can do it, rolling a window down or up can do wierd shit, maybe that coil in that driver is a turd.... i dont know. But there is a LOT going on. Fact is, you need to know your gear/build. I used the -5 tone. My deck distorts at +11 subwoofer volume regardless of volume, +9 subwoofer volume with 28 volume. deck is a kdc x497 (4 volt pre outs). I set the deck at 0 db, the amp at -5db. Subsonic is set at 28 (fixed on the t 1500). I don't know what other info I would use to determine why it clips 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Kyblack76 Posted August 31, 2015 Report Posted August 31, 2015 If you set at -15 you're liable to blow your speakers. It's a slow sunday for me................ i went backwards. meant 0 odb You should be using the -5 tone id expect. Are you sure you know where your DECK distorts at? Or did you set going through the amp? (bet i know the answer there) That said, if your playing over or under tune, you can build heat,.. some songs vs others can do it, rolling a window down or up can do wierd shit, maybe that coil in that driver is a turd.... i dont know. But there is a LOT going on. Fact is, you need to know your gear/build. I used the -5 tone. My deck distorts at +11 subwoofer volume regardless of volume, +9 subwoofer volume with 28 volume. deck is a kdc x497 (4 volt pre outs). I set the deck at 0 db, the amp at -5db. Subsonic is set at 28 (fixed on the t 1500). I don't know what other info I would use to determine why it clips You set the deck at 0db, and the amp at -5? wft ? You FIND clean deck level, set amp to that.... you cant "set" both. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
