r_sherrer29 Posted August 31, 2015 Report Posted August 31, 2015 I am taking out my jump seat in my silverado in hopes of getting a stock GM center counsel to beef up and make a ported box with my single X8 firing out the back or maybe an X10 out the back?? I'm only using it for my sub, and I'm going to make a gauge mount for the SMD gear. So do I work with the stock one or go right to custom? My worry with custom is I have seen 10,000 shitty ones and 10 good ones. I'm torn and could really use guidance and advice from people who have built a center console enclosure. 2011 Silverado Ext Cab Pioneer 6100NEX SkyHigh 1/0 XS Power Polk db521 coax in rear Skar 6.5 Components Sundown SAE1000-D Fosgate P600x4
Moreno93 Posted September 1, 2015 Report Posted September 1, 2015 Custom. You cant even fit a 6.5" in the center console after a box
r_sherrer29 Posted September 1, 2015 Author Report Posted September 1, 2015 Ehh with heavy modifications you can fit something (looking at one now)...but at that point why not do custom I guess. Any pictures or recommendations? 2011 Silverado Ext Cab Pioneer 6100NEX SkyHigh 1/0 XS Power Polk db521 coax in rear Skar 6.5 Components Sundown SAE1000-D Fosgate P600x4
Moreno93 Posted September 1, 2015 Report Posted September 1, 2015 Well that was without any adjustments to the console itself. But if i was putting anything bigger then a 6.5 i would just take it out and put a wood box/console. It would probably reduce alot of noise vs using the console itself.
gckless Posted September 1, 2015 Report Posted September 1, 2015 You could just do a wood ring, and then glass it onto wherever you want to mount it, then glass the whole inside. If you want to keep it somewhat stock. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
r_sherrer29 Posted September 1, 2015 Author Report Posted September 1, 2015 The plan if I was going to do stock would be to gut it, glass entire inside for strength and then maybe see if I could do a slot port on bottom of the floor. I just hate the boxy looks that 99% of people go with; thy just don't flow with the interior. I really enjoy the stock curvature. Maybe parts of stock console with custom parts? 2011 Silverado Ext Cab Pioneer 6100NEX SkyHigh 1/0 XS Power Polk db521 coax in rear Skar 6.5 Components Sundown SAE1000-D Fosgate P600x4
Moreno93 Posted September 1, 2015 Report Posted September 1, 2015 You could but then you'd also have to seal it aswell. The part closest to the dash is wide open. Port would have to come thru cup holders or something What year btw?
r_sherrer29 Posted September 1, 2015 Author Report Posted September 1, 2015 Its a 2011 extended cab. I think I am going to order a perfect curve and lay some templates down then jump on SolidWorks and see what I come up with for a design and hope my skills are good enough to accomplish it haha. Any recommendations on the perfect arc things? One that olds its shape really well. 2011 Silverado Ext Cab Pioneer 6100NEX SkyHigh 1/0 XS Power Polk db521 coax in rear Skar 6.5 Components Sundown SAE1000-D Fosgate P600x4
Broke_Audio_Addict Posted September 1, 2015 Report Posted September 1, 2015 One of the sexiest center console builds ever. Bigger truck then yours but you could use the same general idea. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
r_sherrer29 Posted September 1, 2015 Author Report Posted September 1, 2015 One of the sexiest center console builds ever. Bigger truck then yours but you could use the same general idea. Is he on here? Would love to get ahold of him for some ideas and tips! 2011 Silverado Ext Cab Pioneer 6100NEX SkyHigh 1/0 XS Power Polk db521 coax in rear Skar 6.5 Components Sundown SAE1000-D Fosgate P600x4
