MOHpro Posted September 10, 2015 Report Posted September 10, 2015 I am going to be doing an install on my 2012 ford fusion at some point next year. My quesion is with my set up, does tweeter placement really matter that much? I am thinking maybe putting the tweeters directly above each mid range speaker. Here is my set up.... Total system RMS: 6250 Front Doors: 3 sets of Skar 6.5 components (200 rms per set) Back doors and rear deck: Alpine type R 6.5 coax Subs: 2 12" Skar TXL (2500 rms each) Speaker amps: 3 Skar 125.4 D Sub amps: 2 Skar 2500.1 D
ToNasty Posted September 10, 2015 Report Posted September 10, 2015 Tweeter placement makes a huge differance. I prefer mine on axis in the a pillar ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
MOHpro Posted September 10, 2015 Author Report Posted September 10, 2015 I brought my car to my local car audio shop today to get an estimate for them to make me pods for my front doors for the mid range drivers. The guy recommended one tweeter in the A pillar, one in the factory tweeter location ( behind the A pillar, on top of the door), and the third one in the kick panel. My question is, will the third one in the kick panel mess up the sound or staging? Or will the two mounted in the A pillar and factory tweeter location make up for it? Im kinda not understanding having one in the kick panel
ToNasty Posted September 10, 2015 Report Posted September 10, 2015 3 tweeters? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
jcarter1885 Posted September 10, 2015 Report Posted September 10, 2015 Double post Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
jcarter1885 Posted September 10, 2015 Report Posted September 10, 2015 Doing three tweeters I would consider a line array on your a-pillars, I wouldn't do scattered placement but that's just me. 2 components should do the trick I don't really see the need for three sets. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
MOHpro Posted September 10, 2015 Author Report Posted September 10, 2015 Yes. There will be 3 mid range and 3 tweeters. The way he explained it to me was the tweeter in the kick panel on the driver's side would be angled so that it is pointed toward the passenger and the tweeter in the kick panel on the passenger side would be angled so that is pointed toward the driver side
ToNasty Posted September 10, 2015 Report Posted September 10, 2015 That's a lot of speakers. But if you really want that many, do them all in the a pillar ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
MOHpro Posted September 10, 2015 Author Report Posted September 10, 2015 I just wanna make sure the mids and highs blend nicely with the bass, so that the bass doesnt overpower the mods and highs, so that is why I am thinking three sets
hoit Posted September 10, 2015 Report Posted September 10, 2015 i've never seen a tweeter in the kick panel...probably for good reason. 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
