Box Design for a pair of PPI PRO 124's
BoomZoom808
Can someone help me out with a ported box design for a pair of PPI PRO 124's? This would be for a 05 Mazda 3i trunk and the amp I will be using is a Soundstream TA1.2000D for power at 1 ohm
Thiele/Small Parameters
Fs (free-air resonance, Hz) 42.26
Vas (equivalent compliance, cu. ft.) 0.656
Vas (equivalent compliance, liters) 18.58
Qms (Q, mechanical) 7.68
Qes (Q, electrical) 1.03
Qts (total driver Q) 0.91
Re (DC resistance, ohms) 5.8
Z (nominal impedance, ohms) 2 x 4
Le (inductance, mh) 1.47
Efficiency (1W @ 1M, dB) 83.23
Xmax (one way linear excursion, in.) 0.91
Xmax (one way linear excursion, mm) 26.5
Pe (continuous power handling, watts) 1000
Peak power handling (music, watts) 2000
Mms (total moving mass, grams) 260
Cms (mechanical compliance, mm/N) 0.055
Bl (motor strength, Tesla-M) 19.72
Sd (effective radiating area, sq. cm.) 491.03
Sd (effective radiating area, sq. in.) 76.11
Frequency range (Hz) 42-250
Energy Bandwidth Product (EBP) 41
Driver Physical Dimension
Speaker Outer Diameter (inches) 12.44
Speaker Outer Diameter (mm) 316
Mounting hole diameter (inches) 11.06
Mounting hole diameter (mm) 281
Mounting depth (inches) 8.07
Mounting depth (mm) 205
Magnet Weight (Oz) 155
Basket diameter (inches) 12.44
Thanks!
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
What are the max dimensions of your space? What kind of music do you listen to?
Builds:
Thanks Triticum, the max space is 36" w x 17.25" d x 15.75" h and I like to listen hip hop, country, reggae, decaf, dj snt...
I have built a few boxes tuned between 33-40hz for this vehicle and have been happy with the response. The suspension on these subs is stiff so I am not too worried about playing under tuning. I have one of the 12's right now in a box that is 2.75 cubes after displacement tuned to 34hz on 1k and it has not bottomed out and it still hits the lows pretty well. I think a pair in the right box will hit pretty well.
2010 Mazda 3s 2.5L
Knu OFC 1/0
You don't have enough space for a 4 net box on those dimensions, you may want to see if you can get some extra space.
Does it have to be 4 cubes? I have no idea what's recommend for this sub. Manual only gives sealed recommended specs at .9
2010 Mazda 3s 2.5L
Knu OFC 1/0
I am going to try for 3.5 cu tuned to 35-36hz with 60 in of port area
2010 Mazda 3s 2.5L
Knu OFC 1/0
  • Who's Online   1 Member, 0 Anonymous, 1270 Guests (See full list)
