RX4gun Posted October 10, 2015 Report Posted October 10, 2015 Hello, I'm looking to get a Sundown Audio SA-12 D2 REV.3 and was wondering if the Kicker ZX750.1 would work with it. Sorry if this is a dumb question but I just need an answer to be 100% sure, thank you!
jcarter1885 Posted October 10, 2015 Report Posted October 10, 2015 Get a D4 Sundown SA-12 so you can wire to 2 ohms, here is a wiring diagram as well Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
dthomas Posted October 10, 2015 Report Posted October 10, 2015 The sub is a dual 2ohm so you can wire it for either 1ohm or 4ohm. That amp looks to be only 2ohm stable so you would need to wire at 4ohm to be safe and get half power. You could wire at 1ohm but you would be stressing the amp. I would suggest finding an amp that makes its full power at 1ohm.
Wasteland_Audio Posted October 10, 2015 Report Posted October 10, 2015 I wouldn't run it, you have a dual 2 ohm sub that can be run at 1 or 4 ohms, the amp only pushes 375 watts at 4 ohms and isn't 1 ohm stable. I would either find an amp that puts out 500 watts at 4 ohms or find a 1 ohm stable amp. I think that would make you and that nice sub a lot happier.
RX4gun Posted October 10, 2015 Author Report Posted October 10, 2015 Get a D4 Sundown SA-12 so you can wire to 2 ohms, here is a wiring diagram as well This one?
jcarter1885 Posted October 10, 2015 Report Posted October 10, 2015 Get a D4 Sundown SA-12 so you can wire to 2 ohms, here is a wiring diagram as well This one? yes, correct. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
RX4gun Posted October 11, 2015 Author Report Posted October 11, 2015 Get a D4 Sundown SA-12 so you can wire to 2 ohms, here is a wiring diagram as well This one? yes, correct. Thank you very much!
jcarter1885 Posted October 11, 2015 Report Posted October 11, 2015 No problem man. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
RainStryke Posted October 11, 2015 Report Posted October 11, 2015 I would stick to the original subwoofer and get this amplifier: http://store.soundsolutionsaudio.com/products/sundown-audio-sae-1000d.html That amp would pair up perfectly with that SA-12D2. Those subs are underrated anyway, 1K would be just fine.
RX4gun Posted October 11, 2015 Author Report Posted October 11, 2015 I would stick to the original subwoofer and get this amplifier: http://store.soundsolutionsaudio.com/products/sundown-audio-sae-1000d.html That amp would pair up perfectly with that SA-12D2. Those subs are underrated anyway, 1K would be just fine. Thank you for the recommendation, but I'm on a budget and I only chose the Kicker amp because there's one on sale on Amazon for $100. If I could find the amp you recommended for cheaper I would definitely get it!
