ZV4 12 in a 4th order. How many cubes sealed?
Big diff in a 1:1 and 3:1
1:1 is pretty much a ported box
3:1 Gunna have a bigger peak and be louder then a 1:1
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
I'm pretty sure their is a big difference in a 1:1 ratio to a 3:1 ratio. Bandwidth and peak are the first things that come to mind...but I'll have to agree with MrSkippyJ...they're are WAY more seasoned peeps on here that can answer better than I.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
bigger peak=smaller bandwidth, and a smaller ratio will be much more flat with larger bandwidth, and less peak. I think?....
Singer 220 amp alt
A good way for first timers or even seasoned vets is build the enclosure without the ported side loading wall. Find the res freq on the sealed side. Hopefully around 45-50hz... Then when u find that tune your ported side to your seal side res freq... For port area a good place to start is half of the cone area. So for a single zv4 12" port area in a 4th u could start with 60"
Edited by Massivespl
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
4 juicebox 3100s
  • Who's Online   0 Members, 0 Anonymous, 1949 Guests (See full list)
