after big three less voltage
Lights were dimming during bass, been like this since I installed 2nd amp for subs
checked alt and was getting 14.10-14.21 volts several months ago
when radio and a/c were on it dropped between 13.78-14.01 volts
had some 2 awg welding lead and did the big three upgrade today
noticed battery had fluid coming out of fill caps and quite a bit of corrosion on the negative terminal
cleaned it all up took to autozone battery tested fine and showed 975 cranking amps
now my battery indicator on my dash has slowly been pointing more towards negative
not much but it used to point more towards positive
bass seems to distort at volume levels it used to play fine at.
I checked the voltage with accessories off and get 13.78- 13.90 volts
no voltage drop with radio on or accessories
but why am I not getting the 14.41 I used to get?
This is a 2004 ram with the 136 amp stock alternator
running 1000 watts rms on subs and 300 watts rms on highs
Is my alternator on the fritz?
I have been wanting to upgrade to a 275 amp alt I found on ebay but figured i'd wait to see if the big three would solve problem
maybe ive done this alternator in by beating on it too long???
The battery is a cheap mastercraft battery, but I think its the battery not getting enough juice from the alternator.
Any suggestions are appreciated before I drop the $300 to upgrade alternator and battery
thanks in advance
Did you or anyone else put some distilled water into the battery to replace the fluid lost?
Alternator could be going. It wouldn't hurt getting a larger alt that is more likely to supply the current your truck and aftermarket equipment need together, but it might not be your fix.
I think it's your battery. I'd replace that, grab a new alt, and I'd think your voltage would be around 14.4 again. When you did your big 3, did you add the welding wire to the existing connections, or remove the old stuff and replace it with the welding wire?
I added wire to alternator one ground to engine block and one ground to side of truck frame near battery
so added 2 grounds to existing electrical and 1 positve to existing where positive bolts onto alternator
and he checked fluid levels with bulb type baster looking thing and said levels were fine
and my alternator may be having voltage surges which could cause the fluid to boil over
but mastercraft batteries were known for this
so it probably is the battery, but he assured me it was fine and the alternator was fine
but what does he know about car stereos?
NOTHING!
I don't trust autozone for shit except cleaning supplies, because they're cheaper there ;) but the people who work at every auto zone I've been to either don't know shit, or only know how to change the oil which is enough to make them store manager. I'd either fill that battery up, or get a new one (I'd get the new one personally, an AGM, that way no more spills)
Voltage went down after cleaning your battery?
To verify your before/after readings were carried out at the alt, correct?
Voltage output on your alternator will also decrease as the thermal temp of your alt goes up FYI.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
the voltage was tested in several places
showed the same voltage
between 13.78- 13.91 roughly
I turned on A/C and cranked the system and voltage stayed the same
Several months ago I tested the system after installing my second amp and voltage showed 14.01-14.11 respectively...
My lights began to dim and dash lights would dim on my way to work and in the afternoon after work and after a hot afternoon with no lights my system seemed to distort at the same volume
this is when I noticed that my voltage indicator on my dash began pointing slightly toward the "L" rather than the "H'
not much but it always pointed about an 1/8th of an inch toward a positive charge
now it stays about an 1/8th of an inch pointed towards the negative
So I decided to do the big three today hoping I would see a voltage increase on the dash
After the upgrade I checked voltage at amp, at battery and at the alternator
all showed less than 14 volts which never used to happen. even with the stereo at full volume
I am still getting a charge from my alternator but only around 13.78-13.91 volts
I havent driven the truck at night yet to see if my lights are dimming but I can definitely tell that my amp is clipping at the normal volume I play my system at
My amps are rated for 500 watts rms each and my subs handle 350 rms so its obviously having a voltage drop somewhere because the subs are clipping without a change to my gain settings. which are currently set about 1/3 of the way up.
my highs are not as crisp and mid bass response has gone to shit.
I know 1-2 volts doenst seem like much but it has to be the alternator or my battery in my opinion
what battery do you suggest?
I am not interested in spending $300 for a battery.
a 250 amp alternator is $135 on Ebay for my model
so I would like to spend $165 on a battery
Any suggestions?
I told the wife it was going to be a $300 fix so that is my budget
No 250 amp alternator is that cheap. Not a quality one anyways. If it does do rated output it will probably be around 3000 rpms. Look at brands such as dc, singer, mechman. You'd probably be better off buying a new stock alt vs a cheap "ho". As for the battery kinetik isn't bad, they are good for the price
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
  • Who's Online   0 Members, 0 Anonymous, 496 Guests (See full list)
