Need help with enclosure
300spartan
Uh, for what? If your cuts are good, your shouldn't need caulk for the seams. To actually glue the pieces of wood together, I use Titebond II or Titebond III. You can use caulk on the inner seams if your cuts are not perfect and just use a non silicone based caulk.
Quick question, why non-silicone?
Silicon caulking produces gases while it cures that are hard on the soft parts of your sub.
Builds:
If it was left to cure for a week or so before mounting the subs would it be ok? just wondering because i used silicone based caulk on the box i just built :fool:
What Triticum said. I'm just paranoid and I live in ARIZONA so it's hot in our enclosures for half of the year. I'm always worried about the fumes potentially affecting the soft parts of a sub. I don't trust it, even after is "cured" haha.
Cleansierra I didn't start today because I laid out my board and I didn't have enough. The only way I could get enough wood is if I didn't double the top and bottom.
Would that work?
  • Who's Online   0 Members, 0 Anonymous, 2452 Guests (See full list)
