How to use DD-1 with amp more powerful than sub RMS
FWIW I don't even pay attention to sub vs amp ratings anymore.
Don't push it past mechanical limits and if it smells turn it down :unknw:
run a few of YOUR songs with Audacity to find what overlap to tune with... and from there, learn how to actually use your bass knob. Don't just crank it up all the way when you wanna bump.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
A multimeter set to AC. Or just use the DD1 as directed, but back the gain off a solid chunk when the distortion light pops on. Close enough. 16 billion other factors are going to come into play when calculating the exact point when your woofer will fail. That said, it's a solid sub and should take a beating anyway. Don't stew about it too much.
Don't have the sub connected when you set the gain with the dd1. Use the DD1 as the instructions say and after it's all done use A: the dedicated sub level control on your head unit OR B: if your head unit doesn't have a sub level adjustment grab a PAC LC-1 to dial it in without messing with your now perfectly set amp gain. after this its like the others said, use your ears and nose, if its making other noises than the source turn it down...if you can smell it turn it down.
I recommend track 1 in this situation.
