Hi guys i got a problem i tried setting my gains on my amp today but it wouldn't detect any distortion from the head unit.
Hears what im running headunit is a Alpine CDE-113BT Amp is a T1000-1bdCP and the sub is a T2D415.
so i tried setting the gain with the DD-1 it got to max volume on the headunit and it never distorted this was on track one of the CD so i ended up keeping the volume at 32 setting the gain on the amp to that and on the headunit set the subwoofer to +10 after i had set the gains on the amp but i am worried i have done something wrong as it never detected any distortion :s
Any help would be appreciated Thanks sTp.
Posted (edited)
Set sub level on HU to max, find volume clipping point, then set gain on amp. This will allow max output voltage from the HU.
Edited by magillaru
Singer Alternators
Team Asshole
#anothershittysingerbuild
so basically set the subwoofer level to +15 on the headunit then play the 40hz track and when i find the clipping point of the HU back it off by one and set the amp gain to suit?
also this might sound like a stupid question but when using the dd-1 the red lead goes to the speaker positive and the black goes to the amp ground?
Tahnks sTp.
Right guys sorry to bump this but got a question what track do most of you use to set your amp gain up with i have currently used track 3 on the CD but was wondering what you guys normally use?
Thanks sTp.
It's going to depend on your setup and what you typically play.
-5 is going to give you more bass and work well if you're ply a lot of edited music (decaf, etc)
-10 is going to give you even more but be careful (use your nose and ears)
-15 not needed and risky
Singer Alternators
Team Asshole
OK cool guys thanks for all the help will give the -10db ago at the weekend and just be careful also on the disk i can't see a -7.5db tone is there somewhere i can get this?
Thanks sTp.
  • Who's Online   0 Members, 0 Anonymous, 4554 Guests (See full list)
