Setting gains with SMD DD-1 (Alpine headunit)
Hi guys i got a problem i tried setting my gains on my amp today but it wouldn't detect any distortion from the head unit.
Hears what im running headunit is a Alpine CDE-113BT Amp is a T1000-1bdCP and the sub is a T2D415.
so i tried setting the gain with the DD-1 it got to max volume on the headunit and it never distorted this was on track one of the CD so i ended up keeping the volume at 32 setting the gain on the amp to that and on the headunit set the subwoofer to +10 after i had set the gains on the amp but i am worried i have done something wrong as it never detected any distortion :s
Any help would be appreciated Thanks sTp.
so basically set the subwoofer level to +15 on the headunit then play the 40hz track and when i find the clipping point of the HU back it off by one and set the amp gain to suit?
also this might sound like a stupid question but when using the dd-1 the red lead goes to the speaker positive and the black goes to the amp ground?
Tahnks sTp.
It's going to depend on your setup and what you typically play.
-5 is going to give you more bass and work well if you're ply a lot of edited music (decaf, etc)
-10 is going to give you even more but be careful (use your nose and ears)
-15 not needed and risky
Singer Alternators
Team Asshole
#anothershittysingerbuild
  • Who's Online   1 Member, 0 Anonymous, 1414 Guests (See full list)
