2 SSA Evil d2 15s help
jeep187
I have 2 SSA Evil D2 15s with Fresh Recones. The Recones have 4 Stiff Spiders instead of the normal 3 the Evils come with. I am currently running them on 1 Crescendo BC5500 with plans for 2 - BC5500s
My box is 10.13312 Cubic Feet inside after all displacement.
The port inside dimensions are 4.5" wide X 9.25" high X 9.375: deep
I came up with that the box is tuned to 27.5hz
Is this box good or should there be changes. Please give me any help and or input. It is in a hatchback B Pillar Wall
I appreciate all input
Thanks in advance
by the sounds of it you don't have near enough port area, i would make it around 4.5" x 20" and lengthen the port to about 25", that would put you at about the same tuning but give you much better air flow. I have 2 18" in an 11.5cuft box and my port is 4" x 47" and about 34" long and sounds sick as hell. just my advice tho.
I'd recommend even more port than Wasteland did. I'd use no less than 140 sq in. Those are big boy subs and you are putting considerable power to them, there is no reason to choke the output by not using enough port area.
Builds:
agree,
when i swapped from the sp4 to the team aa, (basically a evil) i now have port noise when i lean on it hard, .... im low on area to begin with. That mistake wont ever happen again.
port area is just the width x height of your port, it has nothing to do with the length, that only determines tuning. Right now you're choking your subs of air and the port noise must be loud as hell. Triticum knows his stuff so i would go with whatever he recommends.
I am doing a 153.5db with current port and box. Everyone says it sounds clean. Im not getting any port noise. Can i hurt anything with the port i have
The main thing you will hurt is your output. Just because you can't hear any port noise doesn't mean you aren't getting any port compression, which kills output.
In an extreme case, having too small of part will increase cone excursion around tuning, which is bad.
Builds:
I hope you get the advice you're looking for. I just had to comment about one portion of your post. You gave us your box volume to the hundred thousandth decimal of a cubic foot.
You the real MVP.
  • Who's Online   0 Members, 0 Anonymous, 6960 Guests (See full list)
