bman8891 Posted October 27, 2015 Report Posted October 27, 2015 Im looking at buying a used cadence zrs c1 to run a single dc xl12 d2. Its a 2 channel amp on its website it says mono block but I dont see anything anywhere about bridging it. Will I get full power to just one sub? How do I wire it?
MrSkippyJ Posted October 27, 2015 Report Posted October 27, 2015 looks mono to me. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
reedal Posted October 27, 2015 Report Posted October 27, 2015 Where are you getting two channel from? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
bman8891 Posted October 27, 2015 Author Report Posted October 27, 2015 Where are you getting two channel from? One the website it says its a mono block amp but there are two terminals to connect subs. My question is how to wire it and will it get full power? Only use one channel? Use the + of one channel and - of the other? Do I need jumper wires to connect the terminals?
islandpride684 Posted October 27, 2015 Report Posted October 27, 2015 Where are you getting two channel from? One the website it says its a mono block amp but there are two terminals to connect subs. My question is how to wire it and will it get full power? Only use one channel? Use the + of one channel and - of the other? Do I need jumper wires to connect the terminals? its internally wired in parallel....so either channel will work... edit: here is the manual http://cadencesound.com/content/ZRS-C1.pdf Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
reedal Posted October 27, 2015 Report Posted October 27, 2015 ^^ correct. It's a monoblock. The two connections allows for easier wiring configuration with multiple subwoofers. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
bman8891 Posted October 27, 2015 Author Report Posted October 27, 2015 Where are you getting two channel from?One the website it says its a mono block amp but there are two terminals to connect subs. My question is how to wire it and will it get full power? Only use one channel? Use the + of one channel and - of the other? Do I need jumper wires to connect the terminals? its internally wired in parallel....so either channel will work...edit: here is the manual http://cadencesound.com/content/ZRS-C1.pdf I had already downloaded the manual but was still lost I didn't know it was bridged internally thanks
