Port help for 2 SSA Evil 15s
jeep187
I have 2 SSA Evil 15s
My box Outside Dimensions is 41W x 31H x 21D / Double Baffled all the way arournd 1.5" Birch
My box Inside Dimensions is 38W x 28H x 18D
I have 2 Braces 1.5" x 3.5" x 38" and 1.5" x 3.5" x 18"
I need help with designing a port. I would like to be tuned to 28hz / As you can see my Port is too Small. I dont want to remake the box i would like to Remove this Port and fix this Box.
Box inside Cubic Feet Empty 11.08
Brace Cubic Feet .17
Both Subs Displacement / 2 x .22each = .44
12047127_1036769109676388_37529230262894
So what are the dimensions of your current port? How much power are you running?
The problem you are most likely going to run into is your port is going to have to be longer than your box is deep. You are going to have to have the port wrap around the inside of the box to some degree, which could be tough to implement.
Builds:
It is 4.5w x 9.25h x 9.375d inside port dimensions
I am running a Crescendo BC5500 now and plan on putting another BC5500
Everyone says its real clean sounding and its doing a 153.5db on the Glass
Bro. Again. This measurement is not CUBED. It is square. You are not getting this. By those measurements you have 45 inchest. Of which is LACKING.
Can you help me on designing a port that will work?
Some one said if i make say 2 ports 3 x 10.25 and 2 ports 3.375 x 12.25 Total 4 ports at 9 inches long i will have my port area and tuned to about 28hz
Please give me any input. Thanks
  • Who's Online   0 Members, 0 Anonymous, 3045 Guests (See full list)
