Triticum Agricolam Posted November 9, 2015 Report Posted November 9, 2015 is port compression from when you dont have enough port area? Yes "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
diegoclass2010 Posted November 9, 2015 Report Posted November 9, 2015 sundown zv3 should like the first box... what do you think Triticum? http://www.sundownaudio.com/index.php/products/subwoofers/item/z-series.html
Triticum Agricolam Posted November 9, 2015 Report Posted November 9, 2015 sundown zv3 should like the first box... what do you think Triticum? http://www.sundownaudio.com/index.php/products/subwoofers/item/z-series.html Yeah, a pair of Zv.3 should work decently. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
cocoleveo7686 Posted November 11, 2015 Author Report Posted November 11, 2015 sundown zv3 should like the first box... what do you think Triticum? http://www.sundownaudio.com/index.php/products/subwoofers/item/z-series.html Yeah, a pair of Zv.3 should work decently. hmm maybe ill save up for them. Guess its hard to find something that like 2.1 cubes and takes 1500 rms. Do the zv3 and zv4 need more like 2.7?
gckless Posted November 11, 2015 Report Posted November 11, 2015 Figure out what sub you're going to get based on amp power on tap, then figure out box. Or vice versa. It's usually best to either start with selecting subs based on amp power, then design a box, or (if you have space constraints) figure out your max space available and then choose subs to suit. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
cocoleveo7686 Posted November 11, 2015 Author Report Posted November 11, 2015 Figure out what sub you're going to get based on amp power on tap, then figure out box. Or vice versa. It's usually best to either start with selecting subs based on amp power, then design a box, or (if you have space constraints) figure out your max space available and then choose subs to suit. I have 3400 rms on tap but im limited in space with 4.4 cubes net. I cant fit a 15 so i wanna go with 2 12's. I just know some subs do like bigger boxes and i dont wanna spend 500 each sub. 350 is pretty much my limit per sub. maybe 375
