12" l7s one amp or 2
LoudPackRacing
I have 2 12" kicker l7s dual 2 ohm models. The problem is I can't find an amp that's 0.5ohms stable so I have to wire them in series/parallel for a 2 ohm load. My question is wouldn't I get more out the subs if I just buy 2 amps that are 1 ohm stable and hook up each sub to its own amp?
Yes
Builds:
Get a crescendo 2k and run at .5ohm
Or sundown 2k
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
If you end up getting 2 amps you better have the tools available to gain match, i made that mistake and ended up strapping mine so i could get even power to each sub. I would take massive's advice and just snag up a 0.5 ohm stable 2k.
Those subs won't like the extra power. If anything I would get a 1500 watt amp. A sundown 1500 will push is to its limits and maybe won't last long. I have owned the L7 and they are picky with their rating
Look for a kicker 1500 that is rated at 2 ohms. I know they are still out there I think they are the zx line. Zx1500.1 and run it at 2 ohms.
For a person who is not experience I don't suggest wiring an amp under 1 ohm. Too many stuff can go wrong
Head room is always better for a nice clean signal. If budget allows get a bigger amp then u need and keep gain lower for nice clean power.
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
4 juicebox 3100s
Yeah but how will he set the gains? We don't know his skill level and him asking this simple question shows its not much. Smaller amp will give him more room for error
His not going to hear any difference from 1500 to 2000 anyway and more watts only means more heat that can hurt the coils
  • Who's Online   0 Members, 0 Anonymous, 7625 Guests (See full list)
