mike-g Posted November 12, 2015 Report Posted November 12, 2015 I need to make the wire fit better, but nevermind that,is this considered a decent ground location its were the factory ground was and it check out to 0ohms from batt.to firewall and firewall to alt bracket
mike-g Posted November 12, 2015 Author Report Posted November 12, 2015 Double post admin please delete this on if need be thanks,and pics are in the post above this one
khinds94 Posted November 13, 2015 Report Posted November 13, 2015 Looks really good man. Next time however I would use black ground wire instead of yellow. It messes people up. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
MrSkippyJ Posted November 13, 2015 Report Posted November 13, 2015 the connections look less than ideal but the pictures aren't that great to really be able to tell either. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Lakeshow94 Posted November 14, 2015 Report Posted November 14, 2015 What is your resistance of the ground location vs the battery negative? If it is a low value (below .5 ohm) you are probably alright. If its above that I'd find a different location 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
MotorCityFats13 Posted November 14, 2015 Report Posted November 14, 2015 Looks really good man. Next time however I would use black ground wire instead of yellow. It messes people up. or do what I did.... use blue SHCA for everything!
mike-g Posted November 15, 2015 Author Report Posted November 15, 2015 I have zero ohms on every ground to properly check I measure from the spot I'm grounding to,to the opposite side of the wire or the other grounding spot
