Uriahia Posted November 18, 2015 Report Posted November 18, 2015 My MB Quart amplifier model RA1000.1 will only power on if I use a jumper between the Battery and Remote connections. If I remove the jumper the amp powers off any will not power on. I've looked at the board and can't find anything out of place or burned. Any ideas if the problem?
Skullz Posted November 18, 2015 Report Posted November 18, 2015 Check the output of your headunits remote wire to make sure it is working or not. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
RooTxBeeR Posted November 18, 2015 Report Posted November 18, 2015 Are you talking about if both battery + and remote are connected to the proper places, it only powers on if you have a jumper in between them? Or are you saying it only will turn on if you use a jumper to the remote section, and not if you just wire the battery + and ground. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Uriahia Posted November 18, 2015 Author Report Posted November 18, 2015 Remote, Battery, and Ground connected to the proper places. The amp only powers on if I jump Battery to Remote at the amp terminals.
Skullz Posted November 18, 2015 Report Posted November 18, 2015 Check remote wire for power. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Uriahia Posted November 18, 2015 Author Report Posted November 18, 2015 I'm not getting any power to my remote wire. The wire out the CD Player doesn't even have a current.
Cardboardcat15 Posted November 18, 2015 Report Posted November 18, 2015 I'm not getting any power to my remote wire. The wire out the CD Player doesn't even have a current. This means your accessory wire (where I assume it was connected originally) on the deck is shot. New deck, or find another turn on relay in the car to use. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Uriahia Posted November 18, 2015 Author Report Posted November 18, 2015 Crazy things is I just had my new CD player sent off for the same problem. If my amp was getting to much current from my battery wouldn't my fuse on the amp blow?
everybodyknowme Posted November 18, 2015 Report Posted November 18, 2015 how many amps, eq, fans, etc.. did you have running on that 1 remote wire? Just buy a toggle switch and turn on the amp from that. If a surge through your power wire exceed your fuse rating yes the fuse will blow.
