NorthSPL Posted December 12, 2015 Report Posted December 12, 2015 Looking for some specs on an enclosure for a FI audio SP4 15. It's going in my 2015 Subaru Crosstrek. My max external dimensons are 36.5"w 19"h 20.5"d. Thinking of tuning 30-34hz in a 4.0ft3 enclosure. It'll be powered by a crescendo encore 4.5k either at 1 or .5 ohm. My electrical is a xs power d4700 under the hood, a xp950 in the back and a Golden Auto Electrical 300A alt.
magillaru Posted December 12, 2015 Report Posted December 12, 2015 You might want to consider shrinking that airspace a little. With that power, you'll want 3-3.5 net and around 60 sq in of port would do well. Singer Alternators Team Asshole #anothershittysingerbuild
Mr DeeBeez Posted December 12, 2015 Report Posted December 12, 2015 This is the box that I have for my sp4 15. 4 cubes tuned to 32hz. Box design should be a couple posts in on this thread: http://www.stevemeadedesigns.com/board/topic/197997-fi-sp4-15-box-help-please/ Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
Joe X Posted December 12, 2015 Report Posted December 12, 2015 So here is a suggestion, If you have more than 20.5" D port back may be an option, power: <4000W, amp subsonic filter to 28Hz, figure is just an assembly guide:
miniSPLlancer Posted December 12, 2015 Report Posted December 12, 2015 You might want to consider shrinking that airspace a little. With that power, you'll want 3-3.5 net and around 60 sq in of port would do well. Built a box for a buddy, 4ft3 slot port on SQ 3500.1 at .35 ohm and ate it up. Played down to 22z full tilt. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
