this is for iasca format and im sure db is the same on the voltage, look at page 46 it says the voltage allowed for the class youre wanting to do
http://floridaspl.com/iasca/Section-07-200...019-noprint.pdf
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Street Classes you're only allowed 1 Battery :)
I have seen an SPL car round here using 8 2v Forklift cells in series to get 16v capable of a couple of thousand amperes :)
10.x volts fo' life!
Weight even out between the two when you combine proper wiring configurations.
6v in Series.
12v Parallel.
Maybe?
That's backwards, parallel two 6v batteries, stays 6v, series, goes to 12v, amperage stays same, parallel, voltage stays same, amperages goes up.
Anybody?
Your question has already been answered....
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Point me to it cuz i aint seen shit yet.
What's the reserve then for 6v batteries?
correct...im glad you pointed that out because i read where he put that and i was like :blink: its the other way around
Yes, that is what I was getting at.
By the time you wired 6v batteries out to 12v the weight between the two batteries versus the one 12v would be about the same.
