Rockville M-4 At .5 ohm (no joke)
ShadeTreeMechanic
I like the part where it's says professional peak limiter circuitry which guarantees distortion free music at all levels.
They Could not possibly make up a bigger lie than that.
Yeah i wondered about that too. Maybe a dyno test could show if the input signal gets reduced at a certian level of output?
Pioneer 80PRS
The video of the amp dyno he tested at half ohm, dont remeber the numbers but just search rockville amp on this forum and u will find his post and videos of it on the dyno.
There are better and worse amps out there, alot of memebers gave me advise on better quality amps when i upgrade this year. For what i need now, this amp does well. Did u say u strapped them ? How well was that set up ? Im also running 2ga royal excelence welding cable. It works just fine for what this amp could pull.
Edit : spelling
No i havent strapped them yet. I was just running the single M-4 at .5 ohm.
Pioneer 80PRS
I believe if u test at a higher frequency u will get a higher rating ? Big D did the dyno at 40 hz so even if they rated the amp at 1500 watts rms it still did it close at 40 hz.. i think certified (until distorion) it did 1283 watts and uncertified (until clipping) it did like 1534 watts @ 40hz on the dyno video
My birth sheet said it did 1503 watts at 1ohm what did ur sheet say ? Trying to see if they just mass produce birth sheets with the same number (most likey)
One is 1505
The other is 1503
Pioneer 80PRS
I believe if u test at a higher frequency u will get a higher rating ? Big D did the dyno at 40 hz so even if they rated the amp at 1500 watts rms it still did it close at 40 hz.. i think certified (until distorion) it did 1283 watts and uncertified (until distorion) it did like 1534 watts @ 40hz on the dyno video
(Sorry i dont know how to quote correctly)
I think certified stops when it sees distortion and uncert is at clipping both at 1%. I think .8% is when it becomes audible.
They are both at 1% so i am not sure what the difference is. 1% is 1% right?
Pioneer 80PRS
They are not the same.
