ShadeTreeMechanic Posted January 8, 2016 Report Posted January 8, 2016 Here is my Opti 4001D. I am currently running it on 2 Soundcubed HDS315 subs slot ported at 34hz. Anyone ever see one on a dyno? It is rated at 4000 WRMS at .5 ohms and the subs are 1200 WRMS each with 2 ohm DVC all parallel for .5 ohms. Does anyone think it is over 2400 WRMS? This is the biggest amp i have ever had. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bighossf150 Posted January 8, 2016 Report Posted January 8, 2016 Alot of people like the optis but I'm there are better amps out there. I had a opti 6k and with the amp set clean I metered higher both a bc3500, but if I cranked the amp up into distortion it metered higher than the 3500, oh and a cap fell off the board and was rattling around inside the amp Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
ShadeTreeMechanic Posted January 8, 2016 Author Report Posted January 8, 2016 Alot of people like the optis but I'm there are better amps out there. I had a opti 6k and with the amp set clean I metered higher both a bc3500, but if I cranked the amp up into distortion it metered higher than the 3500, oh and a cap fell off the board and was rattling around inside the amp Thanks for the input! I smelled the voice coils once but it didn't sound bad. I paid $399 for it new. I could have gotten a factory referb for $299. A cap fell off and it still worked? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bighossf150 Posted January 9, 2016 Report Posted January 9, 2016 Fuck no it didn't work lol. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
3vil Posted January 9, 2016 Report Posted January 9, 2016 A cap fell off and it still worked?Fuck no it didn't work lol. Made me spill my fucking beer man!
ShadeTreeMechanic Posted January 9, 2016 Author Report Posted January 9, 2016 A cap fell off and it still worked?Fuck no it didn't work lol. Made me spill my fucking beer man! Too funny! It sounded like the 6K was a tank at first!! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Massivespl Posted January 9, 2016 Report Posted January 9, 2016 You bought the wrong opti amp... That's not the good one. The link I posted is the model that's is the nice 4000d amp.. http://www.sonicelectronix.com/item_44045_Lanzar-OPTI4000D.html c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
ShadeTreeMechanic Posted January 9, 2016 Author Report Posted January 9, 2016 You bought the wrong opti amp... That's not the good one. The link I posted is the model that's is the nice 4000d amp.. http://www.sonicelectronix.com/item_44045_Lanzar-OPTI4000D.html Yeah I know but i wanted to do .5 ohm. Do any of them do rated power? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Massivespl Posted January 9, 2016 Report Posted January 9, 2016 You bought the wrong opti amp... That's not the good one. The link I posted is the model that's is the nice 4000d amp..http://www.sonicelectronix.com/item_44045_Lanzar-OPTI4000D.htmlYeah I know but i wanted to do .5 ohm. Do any of them do rated power?Ya the amp I posted is .5ohm and does ratedhttp://m.ebay.com/itm/NEW-Lanzar-OPTI4000D-Optidrive-4000-Watt-Mono-Block-Digital-Amplifier-/262042387912?nav=SEARCH c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
ShadeTreeMechanic Posted January 9, 2016 Author Report Posted January 9, 2016 You bought the wrong opti amp... That's not the good one. The link I posted is the model that's is the nice 4000d amp..http://www.sonicelectronix.com/item_44045_Lanzar-OPTI4000D.htmlYeah I know but i wanted to do .5 ohm. Do any of them do rated power?Ya the amp I posted is .5ohm and does ratedhttp://m.ebay.com/itm/NEW-Lanzar-OPTI4000D-Optidrive-4000-Watt-Mono-Block-Digital-Amplifier-/262042387912?nav=SEARCH That's the same exact place i bought mine. It shows the power rating of 4000W at 1 ohm? It doesn't say anything about .5 ohm and the 4001D shows rated power at .5 so i dont know. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
