Rage mode (ON) Deck install
Alpine CDE-153 in a 2005 Jeep Grand Cherokee Laredo. Basic stock system with no amps. I cannot get power. Been scouring the internet. Is my best option to run a line off the interior fuse panel for ignition? Bmw isnt even this annoying.
Do you have a multimeter
If yes test your wires
If no abort mission and don't go trying to scavenge something and turn it into a hack job
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Oh and check your fuses first.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Did you buy a harness to install it or are you cutting wires?
Ignition is controlled via CANBUS. So if you just cut the factory harness and are trying to rig it together OR you bought the little $10 harness, you're never going to get it to turn on. Axxess XSVI-6502 is made for your vehicle. It plugs into the factory harness and can read the CAN signal and convert it to a +12V ignition source for you.
And yes. BMW is every bit as annoying and then X10.
THIS ^ good luck, I used the PAC Radio Pro for my Dodge but even with the adapter its a PITA
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Really not trying to be a dick.... but if you guys think either of those vehicles are a PITA, you haven't installed that much.
Nope just the average joe trying to do it myself and save some money, have some fun and learn a little
2010 Mazda 3s 2.5L
Knu OFC 1/0
Gotcha.
To the OP, if you're trying to be a cheap skate at this, yes, you can run your own ignition source from elsewhere in the vehicle up to your new head unit. The XSVI module does however give you parking brake, reverse signal and vehicle speed sense outputs. So if you're installing a double-din with rear cam and/or navi, it makes life quite a bit easier anyway. Also, it comes pre-wired for the steering wheel control adapter. So if you have and want your steering wheel audio controls to work with your new aftermarket head unit, you'll need to buy the Axxess ASWC-1 also. If you have the XSVI harness, the ASWC will plug right into that. No wiring it up! Lastly, the XSVI module will keep the retained accessory power function working. So with the factory head unit, when you turn the vehicle off, the radio keeps playing until you actually open the door. If you run your own ignition wire from another source, you'll lose this feature.
@Firebird I think You have the answer that Im looking for. I'm gonna price this stuff out and talk to my cousin as its his jeep. Those 2 can bus wires threw me for loop. Ive been reading all over and I'm beginning to obtain an understanding. No nav or anything fancy btw. Single din alpine 153 BT with 3 sets of preouts. No steering wheel controls in his vehicle either.
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
