BigHOUSTON Posted January 9, 2016 Report Posted January 9, 2016 before i installed my xs d3400 , stock batt was charging at 14.8v according to my fluke. Once i put the xs power in it was charging at 14.97v. Someone on a Fb page was saying im charging it too high. But cant do much about it since its a stock alt. am i good? Quote
Wasteland_Audio Posted January 9, 2016 Report Posted January 9, 2016 My mechman alt charges at just a hair under 15 volts and doesn't hurt anything. You'll see a voltage gain going from an old lead acid to a new agm battery anyway. .2 volts isn't going to bother anything. Quote
n8ball2013 Posted January 9, 2016 Report Posted January 9, 2016 Is that hot or cold. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
BigHOUSTON Posted January 9, 2016 Author Report Posted January 9, 2016 Is that hot or cold. That was first crank after installation of the battery , it was about 60 degrees today when i did this Quote
n8ball2013 Posted January 9, 2016 Report Posted January 9, 2016 You're fine. Let it run for about 15 minutes Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
BigHOUSTON Posted January 9, 2016 Author Report Posted January 9, 2016 You're fine. Let it run for about 15 minutes Thanks bud, granted i havent checked it again since(approx 1pm). Left the meter at work so do know if its changed or not. Quote
crispy_chick3n Posted January 9, 2016 Report Posted January 9, 2016 You're fine. Let it run for about 15 minutes Thanks bud, granted i havent checked it again since(approx 1pm). Left the meter at work so do know if its changed or not. the charging voltage will change depending on the temp of the alt. a cold alt will charge at a higher voltage than a warm alt. so if in your picture the truck hadnt been running and had enough time to cool down, then it is a cold alt. after running for a few minutes the charging voltage should drop a little bit. Quote This page is crispy_chick3n approved. © crispy_chick3n inc
SLYentist Posted January 9, 2016 Report Posted January 9, 2016 The new battery probably has a lower internal resistance, maybe that has something to do with a marginally higher cold voltage. just a thought Quote Cables and wires almost never fail; the terminations do.
BigHOUSTON Posted January 9, 2016 Author Report Posted January 9, 2016 You're fine. Let it run for about 15 minutes Thanks bud, granted i havent checked it again since(approx 1pm). Left the meter at work so do know if its changed or not. the charging voltage will change depending on the temp of the alt. a cold alt will charge at a higher voltage than a warm alt. so if in your picture the truck hadnt been running and had enough time to cool down, then it is a cold alt. after running for a few minutes the charging voltage should drop a little bit. Was not aware that was a thing, but I do now. Thanks for the knowledge Quote
the Answer Posted January 9, 2016 Report Posted January 9, 2016 My singer 320a has a oem regulator and it chargers at 15.2 normally when the alt is warmed up or at night, 15.0 hot. highest I have seen was 15.7 cold. I'm running d3400 up front and 3 d3100 in rear Quote
