XS Power
before i installed my xs d3400 , stock batt was charging at 14.8v according to my fluke. Once i put the xs power in it was charging at 14.97v. Someone on a Fb page was saying im charging it too high. But cant do much about it since its a stock alt. am i good?
My mechman alt charges at just a hair under 15 volts and doesn't hurt anything. You'll see a voltage gain going from an old lead acid to a new agm battery anyway. .2 volts isn't going to bother anything.
Is that hot or cold.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
You're fine. Let it run for about 15 minutes
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Thanks bud, granted i havent checked it again since(approx 1pm). Left the meter at work so do know if its changed or not.
the charging voltage will change depending on the temp of the alt. a cold alt will charge at a higher voltage than a warm alt. so if in your picture the truck hadnt been running and had enough time to cool down, then it is a cold alt. after running for a few minutes the charging voltage should drop a little bit.
This page is crispy_chick3n approved.
© crispy_chick3n inc
The new battery probably has a lower internal resistance, maybe that has something to do with a marginally higher cold voltage. just a thought
Cables and wires almost never fail; the terminations do.
Was not aware that was a thing, but I do now. Thanks for the knowledge
My singer 320a has a oem regulator and it chargers at 15.2 normally when the alt is warmed up or at night, 15.0 hot. highest I have seen was 15.7 cold. I'm running d3400 up front and 3 d3100 in rear
