250 amp alt
Hi everyone i am trying to figure out, will a mechman 250 amp alt be good enough for a 4400 watt system. Will be running a d 3100 in the rear and a d3400 up front xspower of course. Amps are 2 RF bdcp1500s ran at 2ohms and a 1000 watt rms highs amp so I will be looking at around 4400 watts maybe 4000. Thanks a head of time for any help that is available thinking of running sky high 2/0 or just their 0 gauge wire.
i have a d3400 and a xp3000 + a mechman 250 on about 5k . my voltage drops to 13.8 . belt slip is my issue
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
Ok I have 1 d3400 for the front, do you think that instead of the d3100 I could just use another d3400 and one run of 0 to the back instead of the 2/0.
is their anyone that could help me with this i am trying to keep cost down so if someone could give me som input i would be greatful
at $1.00 more a foot, how many feet are you going to be running because you can either do 1/0 and if its not to your satisfaction do another run..... good plan with an expensive backup plan... or run 2/0 spend what at-least another $20+ but know you have all your bases and future upgradability covered.... since there is no such thing in the car audio world as over kill... lol..... only downside I really see is 2/0 is like trying to feed a field mouse a jumbo hotdog.... make sure you have the room to pass that shit through..... i am not even close to running the quality gear or power as you but I love SHCA CCA and from what I read its perfect for non-competition daily builds where cost is an issue
You only have 250A of charging, which is even under the capacity of the 1/0 OFC wire. So 2/0 would be overkill. The 250A alt, D3400 and D3100 *should* be enough for that system. I wouldn't think you'd drop any lower than 13v.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
my 230A alt held high 13s on my numerous ~4200 watt setups, and low 13s at idle.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
What bats where you running with the set up. I was tryng to see if i could get away with running 2 d3400, one up front and one in the tback.
