Thanks audiofanaticz! I've never really seen the butyl rope before...I wasn't aware of it being two sided! I'll check in to the products you listed above. Back to my question, when gluing liner, would it be best to glue liner to door panel, or liner to door?
Did your car have some plastic with some black tar like glue to keep the rain away from the inner door?
I'm pretty sure that is the same as SS butyl rope, it maybe different but it acts the same. I'm using SS
rope to seal my SMD speaker terminal.
best way to explain butyl rope is to think of a rope.
Now take all the butyl off the deadener so your left with only the foil.
Take that butyl and make it look like the rope, thats what it is. ;)
Its not one sided or two side, or even 3 sided. Its all sided. You could roll it into a ball if you wanted.
That being said, you could also use the butyl rope to stick the liner to your door as well, and maybe easier to get off if you ever have to get back in there to service a window.
Ideally you would want to adhere it to the actual door itself behind the door panel (similar to how the oem vapor barrier was put on), but depending on how overkill you want to go with it you can attach it to the inside of the outer door skin as well.
Sorry I missed this thread.
Application should go - Metal - Damplifier Pro (Self Adhesive, the butyl will stick and not let go) - Luxury Liner Pro
When attaching the LLP you have a few options:
1 . Second Skin High Temp Spray Adhesive (1 Can will cover 36 sqft or 4 sheets of LLP)(If you want to use 3M, please use no lower than 3M90)
2 . Contact Cement like audiofanatic siad (DAP Landau is the best because it can be used on both sides of the LLP, as one is vnyl and spray adhesives do not stick to vinyl)(Note Gray spongy side should always be facing the metal or down)
3 . Industrial Strength Velcro
4 . Double Sided Sticky Tape (Ours will hold the spongy side of LLP but acrylic double sided tape is needed for the vinyl side * we are getting some in stock in the near future)
Thank you to all the SMD members that addressed this thread already, your helpfulness was right on.
Butyl Rope will seal the door/trunk seals semi-permanently so be careful, it is not weather stripping ;-)
Edited by Second Skin
