How to cut mdf for smd terminal
I would not recommend a sawzall. As has been said, get a jigsaw. They're much easier to guide in a straight line, and much easier to take your time, with much smoother cuts.
This is the only way i can think to do it without a saw. Drill holes around the inside of your line. Side by side as close as you can get them all the way around. Knock center out with hammer. Finish with a rasp. Or plunge cut with a circular saw and finish corners with a hand saw. Or plunge cut with saws all (this takes lots of practice).You could just drill a big hole at each corner big enough to fit the blade in. Or Plunge cut with router and free hand it.
Your best bet is to drill a hole for each corner and connect them with the $20 jigsaw that way you won't have to drill huge holes to get it started.
Pioneer 80PRS
