_94fleet Posted January 25, 2016 Report Posted January 25, 2016 Anyone have any experience with Saiga 12s? I have a Arsenal S12 and im wondering should i go with a bcg reprofile or drill gas ports first? It wont cycle low brass target loads. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
3vil Posted January 25, 2016 Report Posted January 25, 2016 I've got an Izmash saiga 12 but I've never had any gas issues with it, unless you count forgetting to change settings after switching from birdshot to magnum buck a problem! Mine has the 3 port barrel and it cycles even the shittiest of cheap loads. Edit: Opening up your ports, or adding one really isn't that hard though. I feel like that would be my first thing to try if I had cycling issues.
_94fleet Posted January 25, 2016 Author Report Posted January 25, 2016 the prob is light loads are inconsistent. i can dump a mag pr two then get 2 fte in a row. heavy loads cycle like a boss B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
n8ball2013 Posted January 25, 2016 Report Posted January 25, 2016 Before I did anything I'd check on parts availability. There isn't much for these. They all run like shit to an extent. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
3vil Posted January 25, 2016 Report Posted January 25, 2016 If you haven't already, pop over to http://forum.saiga-12.com/ and do some reading there. Plenty of ppl have had the same issues as you, and there's a bit a knowledge there about this weapon platform.
Airborne Posted January 25, 2016 Report Posted January 25, 2016 VEPR12 is a Russian Cop gun. Very nice for what they are and at around the same pricepoint it's my choice. Now, if you want a 20 round drum etc then Saiga is the gun for you. I got over that shit real fast.
_94fleet Posted February 7, 2016 Author Report Posted February 7, 2016 tac 47 autoplug and a bcg polish amd it runs like a champ. no probs yet B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
ShadeTreeMechanic Posted February 7, 2016 Report Posted February 7, 2016 When you say it won't cycle, do you mean that it misses completely and the chamber is empty? Does it "Stove Pipe"? Sounds like the timing is off. I had to lube the shut out of my semi auto and after about 100 rounds it started to cooperate. (mine is not a Saga though) 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
3vil Posted February 7, 2016 Report Posted February 7, 2016 He most likely means it's failing to eject. Saigas often will not fully cycle the bolt when using low brass/light charge shells. I have a pdf about polishing the bolt, it's actually about the VEPR but most info carries over.
_94fleet Posted February 14, 2016 Author Report Posted February 14, 2016 i installed the tac47 autoplug and polished up the bcg and trigger. runs good now but still doesnt like anything under 1200fps. cycling as in it would fail to eject. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
