Fiberglass Cloth or Chop mat, Is there really a Difference?
Wood
Lots of ways to build FG parts, but I always try to leave the finished surface alone once it's shaped and add mat/weight to the back side where I don't have to body work it as much.
Takes some planning and depends on your process but keep it in mind.
Static drops are my bag.
Yeah huge difference. Chop mat is going to create stiffer (less flexible) but weaker parts, and is easier to get good results with. Woven cloth will result in stronger parts if done correctly (but this means you need proper strand orientation, which requires a few layers, and correct amounts of resin)
So basically unless you want to get real serious chop mat will be a lot moe forgiving and yield more structurally sound parts. Unless you want really complex curves, then cloth is a must.
Strength will be determined more on the weight of the mat. How heavy is the woven mat you're using? If it's apples to apples on weight, strength should be about the same.
PERFECT! plus I would like to try something different to see if it works better for me... I just didn't want to compromise strength going from one type of fiberglass to the other
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
this is actually pretty smart lol I'm gonna see if my project allows me to do this!
ELECTRICAL:
-Singer 230a
-Northstar gr34
-100% Welding Cable
FRONT STAGE:
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-Roof Spoiler
And to add to that, cloth is stronger because you have long unbroken strands. If you are using small pieces of cloth or cutting them to get them to conform you are better off with chop mat, or hell loose strands.
I was gonna use a large sheet for majority of the project and just cut smaller pieces for the one curve I have which it's really not that curvy
ELECTRICAL:
-Singer 230a
-Northstar gr34
-100% Welding Cable
FRONT STAGE:
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-Roof Spoiler
I use solarez ... pretty bad ass stuff! no complaints as far as that, just dont like the inconvenience of the mat.. I use 1.5 oz myself, but found 4oz 4hs fiberglass cloth for a good price also that is supposed to conform to curves (even though i would cut V's in the material to get it to curve)
I've never used the UV resins so I have no idea how they layup.
I really appreciate everyone's response!
Thank you!!
ELECTRICAL:
-Singer 230a
-Northstar gr34
-100% Welding Cable
FRONT STAGE:
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-Roof Spoiler
Alright so I think I'm leaning towards the cloth and around the small curve I have, I'll break up the cloth for the extra strength...
Thank you fellas!!!
ELECTRICAL:
-Singer 230a
-Northstar gr34
-100% Welding Cable
FRONT STAGE:
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-Roof Spoiler
  • Who's Online   1 Member, 0 Anonymous, 1561 Guests (See full list)
