I wonder how hard it would be to get a 4.2 vortec (08) in there... That's like 270 hp right there
Why waste your time on a motor swap for a 6 cylinder? Get a 4.8 or 5.3L LS series motor and be done with it.
apart from the costs...
this is the way to go...
5.3 are going for $600 around here you just have to search.. i found an lq4 for $750 that im going to go see sometime next week.. found an lq9 for $2200 obo with transmission included.. not that expensive
compared to a vortec tree fiddy, it's expensive. But fuck a vortec treefiddy. Garbage boat anchors. Weak bottom ends, god awful injection system. Heads flow well, for what they are...
but lsx swap 88-98 ftw. Would be cheapest to buy a full truck that is totaled or whatever... then go from there.
The only ls I'd swap in would be a truck 6.0 or a truck 5.3 and people want way too much money. I'd rather just cam and stroke a vortec 350, throw some nice injectors and tune it. Call it a day
Ballin' on a budget.
Haha, have at it dude. And don't discount the 4.8, it's a stout bitch. The entire LS line is stout and capable. Don't think you NEED a 6.0 to make it worth it.
have you price out injectors for one of those intakes?
it's ridiculous. Unless you cop a marine intake... For the money you'd spend on a stroker kit, with machine work, cam, valve springs, and a mild freshing up, oh plus a tune...
and where are you at? Basically anywhere, you can roll down to nearly any junkyard and pick up a lm7(truck 5.3) for like $4-600. And a 60 or 80e for another 4-600 more. Trucks a 97? It very well may have an 0411 pcm if I'm remembering my stuff right...but if not, that's another $100.
For like $2 grand, you could have a 5.3 lm7, pick up a set of 243 heads, a cam kit, and a 60e with wiring harness and pcm dude.
or fuck, save another $200 and get a 4.8, do the 243 heads and get some ARP studs while your at it. cammed 4.8 with decent heads + nitrous = hell of a combination.
Bigger injectors and a tune = way worse gas mileage.
If your goal is to do the swap to gain mpg you're about to be in for a surprise.
You want to gain mpg keep the 4.3 and track down the turbo parts from a typhoon and male your a 4.3 turbo.
Or do a 4bt swap.
Or do a 4bt swap.
There's an expensive swap
Worth it.
They used to be really cheap, like less than $1k cheap.
Now they are like $3500- $4k if you're lucky.
Still worth it.
