help choosing between PPI 900.4 and NVX jad 800.4
akuma4u
Hey
i need help choosing between these 2 budget 4 channel amps: the ppi 900.4 and nvx jad 800.4 amp
both do around the same numbers at 14.4 V, but the NVX amp was dynoed but they only dynoed it using 2 channels out of the 4 and it gave a much higher number than it would if they tested it using all 4 channels.. Not sure if the PPI was rated using 2 channels or 4.. but im pretty sure they dynoed it using all 4 channels as the numbers seem more accurate.
having said that and not knowing exactly what the NVX amp does with all 4 channels @ 4ohms.. which amp do you guys recommend?
I have heard they are all the same inside/use the same boards etc.. not sure if its true or not..
the PPI is 20 bucks cheaper as well..
so , anyone that has ever used these amps have any feedback or recommendation please let me know. Thanks
heres the link for the dyno for the NVX 4 channel (they did the test using only 2 channels so their numbers are not accurate for a 4 chan load)
i jus got that jad800.4 like 2 days ago, havent hooked it up yet though
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Whats the difference between the two? :peepwall:
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
hmmm.. i dont think there is any.. other than aesthetics.. i believe its the same board? same performance?
I have the JAD 800.4 and love it, you wouldn't be disappointed.
ok i went ahead with the NVX JAD.. my research shows that they are basically the same amp.. there are several companies that have all cloned this amp.. not sure who the originator was , i think it was PPI.
:good:
LMFAO so true
:blush:
lil update on mine, got it installed last weekend, this weekend it cut off a few times, not sure what happened exactly. it cut out then turned back on after about 6 seconds, did it multiple times. not sure if vibration was to much for it or what
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Put a 900.4 in a coworkers jeep of mine, nice little amp and has worked without any issues. Has it on 2 Morel Maximo 6.5" component sets.
  • Who's Online   0 Members, 0 Anonymous, 783 Guests (See full list)
