prodigal_son Posted March 6, 2016 Report Posted March 6, 2016 Installed in my son's car about Last July or August. Unit was brand new. Apparently it started rebooting frequently after a few months of normal use, then it progressed to a blank display and no lights on buttons. Now buttons are illuminated, but no display. Pioneer says it's because the weather turned cold, but it doesn't matter how warm you get the interior of the car, it won't come back to life. Does anyone have experience with this issue?
Pasta Prime Posted March 6, 2016 Report Posted March 6, 2016 I had a Kenwood do something similar and it was because I had put some corrupted files on my flash drive I use for music. I reformatted the drive and and put the music back that was there before i put the new files on and it fixed my issue. Not sure its your situation as mine didn't blank out but rebooted every 10 seconds. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
prodigal_son Posted March 6, 2016 Author Report Posted March 6, 2016 Thanks for giving us something to consider Pasta Prime.
Gravlin216 Posted March 8, 2016 Report Posted March 8, 2016 Installed in my son's car about Last July or August. Unit was brand new. Apparently it started rebooting frequently after a few months of normal use, then it progressed to a blank display and no lights on buttons. Now buttons are illuminated, but no display. Pioneer says it's because the weather turned cold, but it doesn't matter how warm you get the interior of the car, it won't come back to life. Does anyone have experience with this issue? That BS. I have the AVH-X4800BS and live in northern NY where it get's pretty damn cold and this doesn't happen to me. I would just try to reset the headunit back to factory setting or try to load the previous saved settings. http://www.manualslib.com/manual/899365/Pioneer-Avh-X5700bhs.html?page=6#manual Try unhooking the battery for a min or hitting the reset button on the device.
prodigal_son Posted March 8, 2016 Author Report Posted March 8, 2016 Gravlin216, I was wondering if other models were doing this. Do a little googling and you'll find others who are experiencing the same problem, and at least a few of them were told the same thing by Pioneer customer service. I couldn't agree more that it's bs, who in their right mind would make a car stereo that won't tolerate cold weather? We unhooked the battery with no luck, not sure the 4700 has a reset button?
reedal Posted March 8, 2016 Report Posted March 8, 2016 I had a similar issue with my 80prs during the winter. I redid my ground for the HU and the issue stopped. Might want to try that. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
prodigal_son Posted March 9, 2016 Author Report Posted March 9, 2016 I had a similar issue with my 80prs during the winter. I redid my ground for the HU and the issue stopped. Might want to try that. Interesting....I assume that you weren't having problems before winter? Can't hurt to check it out.
Amart88 Posted March 9, 2016 Report Posted March 9, 2016 Tuned in as I just installed the same HU last month. OP, let us know how you make out. I have a dedicated ground to solid dash metal on mine. My 2005 s10 blazer build. 4 zcon 18's walled.
reedal Posted March 9, 2016 Report Posted March 9, 2016 I had a similar issue with my 80prs during the winter. I redid my ground for the HU and the issue stopped. Might want to try that.Interesting....I assume that you weren't having problems before winter? Can't hurt to check it out.Nope. No issues until December, then every time I would turn it on, I'd have to reset the clock and other things on the main menu. Luckily, all my crossover points, T/A, and other settings for the speakers were saved. But it was rebooting itself every time until I messed with my grounding point. Apparently the factory radio ground wasn't good enough for the PAC adapter module and the 80prs during the coldEdit: by that I mean, the factory ground connected to the PAC, and then the PAC had another ground lead for the after market HU to connect to SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Amart88 Posted March 9, 2016 Report Posted March 9, 2016 I had a similar issue with my 80prs during the winter. I redid my ground for the HU and the issue stopped. Might want to try that.Interesting....I assume that you weren't having problems before winter? Can't hurt to check it out. Nope. No issues until December, then every time I would turn it on, I'd have to reset the clock and other things on the main menu. Luckily, all my crossover points, T/A, and other settings for the speakers were saved. But it was rebooting itself every time until I messed with my grounding point. Apparently the factory radio ground wasn't good enough for the PAC adapter module and the 80prs during the cold Not trying to thread jack, in for info. So you had a separate interface from PAC to wire the HU to the car? I have a lan-9 interface in mine. Good to point out.Did the OP have any other things in between? My 2005 s10 blazer build. 4 zcon 18's walled.
