New to the forum need some help
Hello, i'm new to this forum my name is Max from the Rio Grande Valley. Currently looking to learn about how to correctly upgrade the car audio on my 2010 Camaro RS. It currently has all oem Boston Acoustics audio. The only thing I have added is :
2 12" DB Drive PLT12D
Specifications :
Subwoofer Structure : 12" dual 4 ohm voice coil
Maximum Power : 1500 watts
RMS Power : 750 watts
Sensitivity : 88dB
Magnet Size : 180 oz.
Interfire T-1000M Amp
Channel: 1 ch Mono A/B -- Total Max Power: 1200 Watts -- 4 Ohm at 14.4V 0.3%THD (RMS): 330w x 1ch -- Power Supply: Full PWM -- Variable Low-Pass: 50Hz - 250Hz -- Heatsink Length (mm): 13 x 10 x 2 1/8 -- Fuse Rating: 2 x 30 Amp
Next step is upgrading 6.5" speakers and 6x9 speakers as well as voice amp. Any suggestions on leading me to the correct way to set up my car audio would be perfect thank you.
I would check in the mids and highs section
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Anyone that can help please?
Just got some 6x9's and a voice amp
Sony( Sony XM-GTX6040)voice amp:
4/3 Channel GTX Series Car Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan.
2 ohms: 70 watts x 4 chan.
Max Power Rating:
4 ohms: 110 watts x 4 chan.
2 ohms: 150 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Max power output: 600 watts x 1 chan.
DB692.2
Specifications:
6x9 coaxial speakers
Maximum Power: 180 watts
Nominal Power: 60 watts
Freq. Response: 45Hz - 20kHz
Sensitivity: 92 dB
Features:
Poly-injected cone
Rubber butyl surround
Mylar dome tweeter with ferro fluid cooled magnet
Always go bigger on your amp choices as it allows for higher volume without distorting, and most speakers can handle more thermal power than clipped signals.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
