disc brakes all around,brake pedal spongy at times
if it's on a newer vehicle with ABS, a lot of the time you can get them to enact a "self bleed" if you will, by performing a rapid stop on a loose surface that will cause the ABS to engage. Most service shops have an IDS scan tool that will cause the ABS to cycle...
but if it's on the foxbody in your sig, take it back.
yea i left a message, ill call again monday and let em know needs to be done asap , yes it is the foxbody in my sig. tryna get it all squared up this year before I start chuckin group 31s in it
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
  • 4 weeks later...
Updated*
The brakes fixed themselves over the weekend after the work was done, I think it was "brake pedal knockback" from the more efficiently functioning calipers in the rear
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
The brakes fixed themselves? That sounds scary.
Pioneer 80PRS
"brake pedal knockback" ?
Now there is a new term, for me any ways. I love it when brakes fix themselves.
It could have been that the pads just needed broke in which is rare or the pads they installed were made out of different materials than your old ones giving you a different feel in the brake pedal.
For the most part anytime you replace the rear pads or shoes on a vehicle it will help the pedal immediately, I call them big toe brakes and that is the way I like them.
