New box, will it work?
I've been thinking about building a new box for my burban to get low and nasty. I drew this one up last night and was hoping for a little input/advice.
Equipment:
x2 18" DC lv6m3
x2 Audiopipe 4500apk
New box specs:
16cuft - 27hz
Old box specs
11.5cuft - 32hz
Any input would be greatly appreciated, thanks!
Whoa, you are going to get 2 DC lv6 18's... but run audiopipe amps?
and btw, tuning and box volume isnt enough to give a loosely estimated idea of if it will do well or not.
same Boards vs the components that are used on them boards are vastly different
I can never under stand how people will pay thousands for subs then buy 200 dollar amps to run them
good luck!
I am not sure they use the same boards tho
nope.
I thought it was funny you had to post a vid is all........... yes audiopipes work yes they make noise if you like em run em
just there is much cleaner nicer ones out there but they make you happy
more box specs is needed
Didn't have over $3000 do drop on amps, but anyway port size is 45.5" wide, 4.5" tall, and 36.25" long, 16ft3 after displacement, outside dimentions come out to 48.5" wide, 23.25" tall, 45" long
I think your new box will accomplish your goal of providing more low end output. You will give up a little bit in the 30-50 hz range, but you should gain significant output below 30 Hz.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 531 Guests (See full list)
